losh1971
- Jan 17, 2010
- 22,625
- 22,431
- 113
- Location
- North Tas
- VE Series I SS Ute
So I replaced the gasket on the water pump as I saw a green tinge around the edge when I used the acid on the engine. I ended up replacing the gasket and used sealant. Trouble is I now have a weep. I can't tell for sure where it is coming from, other than I know it's the pump. I really hope it's not a third or fourth failed pump in three years as this is getting beyond a joke if it is.
I am probably going to pull the pump again but not sure whether to go back to before and only use sealant on the bolts and not the mating surfaces?
