jeepster
The fuel pump and sender is fitted to the side of the tank with micro-encapulated bolts. These are no longer available from Holden parts. I would guess that Loctite or Permatex purple could be used. That is the low-strength version for tiny bolts. However, the cure time is 24 hours at 22 Celcius.
Also does Loctite/Permatex resist the aromatics in petrol? Or is there some special gunk that is needed to seal threads on a petrol tank?
