Seems transmission coolers really are beneficial...
rob drag racer
vn vp drag nut
golden beach
forums.justcommodores.com.au
vp 3.8 with gas new project vn s1 guted strip only
i agree best to run it via the rad after all in a normal situation the rad isn't to bad i wouldn't run the a/t to cold you may cause damage
Morton
For external use only
Fairstar the Funship
You should rotate your diagonal cooler to actually face oncoming air :)
jas98
34
maryborough QLD
vs commodore V6 S2 and a BA XR6T
i put one one me vs the other day..however im not sure if i hooked it up right as i ran the top hose from the radiator to the cooler then cooler back to the trans..? is this teh correct way? as i want it to go from trans to radiator then radiator to cooler then back to trans but dunno if if i hooked it up right:p
cheers
savage1987
Donating Member
www.facebook.com
I THINK you actually need to put it in the bottom hose. The top one is the feed line FROM the auto. At least, I really hope it is otherwise mine are in wrong :p
**someone able to verify this?**
pando666
milk comes in 2 litres
sydney
vs exec
So does anyone know for SURE which hose to put the cooler in bottom as you(savage)has done or top as Jas did?.
azzfox
Braaap.
Yarra Valley, VIC
www.facebook.com
VE SS-V
Id say bottom which is the return line. The radiator cools the fluid to engine temp which is still quite hot. You dont want to cool the fluid through a cooler then heat it up again before returning to the trans.
