Seized Brake Caliper Ve sv6 commodore 2010 model
HedgemasterMatty
39
2010 holden VE commodore sv6 ute
Hi everyone,
I recently got my brakes fixed by a tyre shop that does brake repair. After replacing the discs and pads I found d the brakes were sticking. Returned it to shop and they now tell.me my brake calipers have seized. How can I rectify this issue??
losh1971
North Tas
VE Series I SS Ute
Need to remove the caliper, dismantle clean and replace the seals if the pistons have become corroded on the hardened surface they will need replacing as well.
HedgemasterMatty
39
Thanks mate,
Wish I knew how to dismantle the calipers. Calipers were fine before Tyrepower did the brake repair.
losh1971
North Tas
VE Series I SS Ute
Thanks mate,
I just rebuilt my rears. It's fairly straight forward just need basic tools and a compressor.
stick3
newcastle nsw
vz sedan vs ute gsx1400
undo the 12mm bolts they screw into the slide pins and hang the caliper with a bit of wire to the spring , twist the slide pins that will tell you if there seized
and another thing ve pads have inner piston side and outer these have two protrusions in the aches of the caliper
losh1971
North Tas
VE Series I SS Ute
Mech should have done this when replacing the pads and rotors. Surely they didn't just wack pads in and not grease and inspect the calipers. Although they should have really picked up on the sticky pistons if they were a problem when they did the repairs.
HedgemasterMatty
39
I noticed the front right was stinking after use of car, days after repair. Took it back and after 1 hour on the host they told me ute was not driveable and wanted a further $200/caliper to recondition. Wish they told me they were sticking before I drove it. May have damaged the new rotor
stick3
newcastle nsw
Mech should have done this when replacing the pads and rotors. Surely they didn't just wack pads in and not grease and inspect the calipers. Although they should have really picked up on the sticky pistons if they were a problem when they did the repairs.[/QUOTE
you would think so, could be a lot of reason why he missed it
HedgemasterMatty
39
Buying a caliper kit tomorrow so hopefully this will fix the issues.
losh1971
North Tas
VE Series I SS Ute
Stick, are you saying the slides never need greasing on the VE??
