i been doing my brakes for nearly 40 years both disc and drums when you undo the bolt lift up the caliper you check move the slide twist slide pin pull push it and make sure the rubber boot is not split and covers it
have a look at all the youtube vids on how to change ve brake pads but i know the pads have inner and outer and we have seen it on here there been stalled the wrong way and it is very easy to do if you are in a hurry or don t know
i got ve brakes on my vs ute the ve calipers have a metal shim insert the pad slide on and these are suppose to be replace too i had a problem where it wearing a groove in the driver side rotor i have a box of them (cheaper from repco) here so i just replace it with a new one
https://www.ebay.com.au/itm/COMMODO...120092?hash=item4b60c5c19c:g:WSIAAOSw6JNckvqL
