Sensors, senders and the like
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by mrhotdog, Jan 9, 2008.
  1. mrhotdog
    mrhotdog What Would Jesus Do?.....
    Adelaide, South Australia
    2003 VY S1 Acclaim
    hey
    can anyone give me an easy explanation as how to change the coolant temp sensors/ senders, i think thats all there is? what do they do exactly...
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Remove either one with a ring spanner after disconnecting the wire(s). Reinstal is reverse and if you want to you can put a sealant on the sensor threads though this is optional. Keep the radiator pressure cap on when doing this to prevent loss of coolant....also do it with a cold engine!
    The sensor measures the coolant temperature - this information, along with data from other sensors is used by the ECU to calculate the correct amount of fuel the engine needs to run efficiently.
    The sender simply measures the temperature of the coolant and send its information to the coolant temperature gauge in the instrument panel.
  3. Morton
    Morton For external use only
    Fairstar the Funship
    Yeah, they're behind the alternator - there's two of them.
    One has a single wire, and controls the dash gauge. The other has two wires, and feeds back to the ECU. :)
  4. mrhotdog
    2003 VY S1 Acclaim
    so they are both behind the alternator, i have a VS. do i have to take any big stuff out or are they easily accessible?
  5. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    His car is a VS so I assume its got the ecotec engine so its not behind the alternator. It just below the thermostat housing.
  6. mrhotdog
    2003 VY S1 Acclaim
    both of them are below the thermostat housing? this is gettin confusing lol
  7. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    Not the best pic but have a look where the arrows are pointing. They are the sensors. (Ecotec)
    Hope this helps..
  8. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    So it's next to the supercharger.... where has my supercharger gone ??? :cry:
    kopper69 likes this.
  9. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    Forget the charger... the sensors is on the engine. Underneath the top hose.
