series 1 and series 2 computers are they same?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by kowan, Feb 11, 2007.
  1. kowan
    kowan Clayton's Commodore
    Far North QLD
    91 Clayton's Commodore/Toyota Lexcen
    vn series 1 and series 2 computers are they same?
    Can I replace either of these to my VN series 2 motor?
  2. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
    ECU's are the same, memcals are different.
  3. kowan
    Far North QLD
    So can I just bolt the series 1 ECU box into the car for my series 2 motor?
  4. SweetWagon
    SweetWagon booosted
    Springwood NSW
    yep, straight swap.
  5. kowan
    Far North QLD
    Yes it does work.
    The cooling motor fan was working when the motor wasn't on and the yellow engine light was on while the motor was running and flicking on and off and someone said to check the code to see what code was showing 12 12 12 all ok there. Someone said to replace the Temp sender unit. I changed it and the fan stop. The following day the fan started to start again while the motor was off. "BUGGAR" So I replaced the coil pack thinking it may have been that. "WRONG" That didnt fix the problem. So I changed the ECU "WOOHOO" That fixed it. Bloody old cars.
    Thanks for all your help everyone, Cheers
  6. greenfoam
    greenfoam New Member
    VP Executive R-spec
    Does it go faster with the series one memcal in it:)?
  7. kowan
    Far North QLD
    Only if I put one foot out of the door and kick my way to freedom I get a extra 2k's
