Series 1 engine into vr
lemsua
Apple Eater
NZ
www.ahoythere.co.nz
VN Exec S1 3.8
I know there is a thread about this already but I have a series 1 vn engine that wants to go into a vr
have full vr loom and everything and vn loom and ecu, will use vr auto
is it doable or just to much messign around?
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
you need to add the cam position sensor which means the front timing cover and trigger on the camshaft as well to run the auto ecu and tunes for vr so you can run the box.and the tune is way out for the vn engine will not go very good and will use more gas.
lemsua
Apple Eater
NZ
www.ahoythere.co.nz
VN Exec S1 3.8
Cheers for that, can i not use the vn ecu so the tune is all good?
no offense but the bold text in your signiture is rather...err....bold ;)
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
no cause you are VR auto and it needs the vr auto ecu to control it
