IsaacSV6
- Aug 22, 2019
- 3
- 0
- 1
- Age
- 23
- Location
- Penrith NSW
- 2007 VE SV6
Thanks guys
Also a standard usb OBD2 device isnt going to communicate with the headunit at all since it doesnt communicate over the standard CAN communication gateway, only the ECU for engine data can use an OBD2 elm device. Youll need something to jump onto the sw can bus.
Just a heads up on the work involved in reprogramming a head unit. Not only do you need programming knowledge, you also need full understand the CAN protocol, how to interpret messages, how to filter messages, and to inject custom frames etc.. On top of that you will also need to know the unlocking algorithm to be able to change/write any information to the head unit.
Its kinder like with tuning a ECU I guess, cant do anything unless you have reverse engineered the device and know the password combinations to unlock it, huge amount of time goes into that.
The new screen has to be recoded to your vehicles VIN etc. Holden can do this and there are probably other as well. So they not pulling your leg.
Envyous Customs will set you right, he knows his stuff.
