hey guys, alright an emergency requires a s1 coilpack to go on my mates vp (which has a series 2) now thing is the series 1 doesnt have lead numbers on it, and also is a diff patern, so basically asking wat leads go to wat spot thanks guys
It's all in the owners manual, the different coil packs and a diagram of the motor and it's firing order. have a read of it
My leads had numbers on it wasnt hard to work out when i did the swap anyway the most forward facing cylinder is number 1 then it continues onwards swapping from side to side. Series 2 coilpacks are numbered i dont see why its hard t figure out
he worked it out once he was told that the numbers were moulded into the plastic next to the coil pack screws into the dfi module case CLOSED
