Series 2 Headunit upgrade
Bosscoe
VT Calais
Hey guys,
I'm in need of a little help please. I want to upgrade the headunit on my 08 VE Calais, I believe I have a series 2 due to the dual zone headunit. I've read on forums and google, but I keep coming up with series 1 to series 2 conversions (not what I'm after). So is there anything out there like this https://automotivesuperstore.com.au...MIrKel2tGi5AIVwoBwCh3W7w1JEAQYBCABEgL0pvD_BwE available for me? Last time I checked this part wasn't available for dual zone hence why a seller on FB was selling it. What are my other options? Will I have to go somewhere like alpine etc...to have a new headunit installed? more options the better.
Cheers guys.
Fu Manchu
WA.
All the series one components can be retro fitted to a series 2.
Then fit the series one options. We still have to wait for a dual zone HVAC controller from Aeropro.
In the S2 Calais, the available options mean retro fitting lower spec components and the end result isn't great.
I think the S1 Calais dash layout is a bit simpler and classier in styling.
Once you have done the series one conversion, you can use the Alpine touchscreen HVAC controller and match to a huge array of options for Android Auto and Apple CarPlay headunits.
I can try make a list of parts to find to do the swap.
The S1
Bosscoe
VT Calais
Ouch,
So I have to downgrade in order to upgrade my headunit fmd holden.
By "end result isn't great." what do you mean by that sorry?
A parts list would be great yes please.
What I really want to do is throw in a double din headunit for now, than upgrade later on down the line.
I'd prefer to have Alpine or Rockford run my sound system rather than an ipad/android.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Does your Calais have an IQ fitted currently?
Fu Manchu
WA.
So not great means having the top panel (in series 2 form) as a slightly different black plastic (almost shiny) finish. It means having two round air vents and the whole look isn’t as nice as the Calais finish.
I have all the parts in the garage, so can get some part numbers and photos on Friday.
Bosscoe
VT Calais
No IQ fitted on my VE unfortunately.
I see what you mean now about the looks. This keeps getting depressing the more I look into it.
Nah no drama's looking for part numbers buddy, I'll figure something out :/
Asmodai78
VE Calais V Sportwagon
This is my KAYHAN install into a S2 CalaisV, I went to the wrecker and got a second air vent and trimmed the bottom part to fit.
Fu Manchu
WA.
If you don't have the IQ headunit then you have the a series 1.
Dual zone climate control is a feature found on both series 1 and 2.
The photo I posted is series 1.
Series 2 has the headunit screen up higher.
At present, the Alpine HVAC control module is the only real option for installing an after market head unit into a VE with dual zone unless you use the Kayhan unit.
KHOLDEN
Ashhurst
VE S2 SSV Redline ute
08 VE Calais will be a series 1, series 2 are after 2010
Bosscoe
VT Calais
Ok so I got a series 1 dz, and the Aeropro kit is a no go. Damn the Alpine HVAC control module looks ugly. Is it possible to get a double din of my own choosing professionally installed or am I out of luck on that as well?
