Hi guys recently brought a new ssv S2 redline ute and am loving it, my first V8
i am wondering if anyone else has had any problems with the IQ system. Sometimes my sat nav doesnt load up or my ipod freezes or i cant select anything on the touch screen. The only way i can fix it is by turning the car off and on again then everything works fine. If i turn the IQ system off and on again it does nothing i have to actually stop and turn my car off...
Any ideas or had similar problems?
Firstly my iphone was plugged in and it froze? Nothing would work until it re-started the car!
Partial - Device will connect to Holden-iQ system, but the connection may be slow and/or functionality reduced. Apple is aware of device limitations and may address in future iOS updates.
Hi guys I just got my SSV series II two weeks ago and I have the same problems. Firstly my iphone was plugged in and it froze? Nothing would work until it re-started the car! Today, I started the car and the air con controls wouldn’t work? Again, I restarted the car and it all worked fine. (Note: I had to switch the car off, lock it and re started it both times) Interestingly, no problems with the sat nav or connecting via blue tooth though!
I had the same problem on Tuesday. The clock and air-con indicators disappeared from the IQ display. The steering wheel controls stopped working for the IQ functions (volume, mute, radio station, phone button, NAV button). Climate controls all stopped working. I could still change radio station with the touchscreen. I turned car off, opened door and locked it, then unlocked but still didn't fix it. I had to leave it for 30 minutes before it worked again. I did record a video from my phone, maybe I should upload it to youtube.
My car is less than 2 months old, yet I have had it back to the dealer several times for an intermittent fault with the IQ. The problem happens at startup, and has happened at least 4 times. Typically I lose the clock, rear camera [although rear sensors work], control of the aircon fan, the ability to change radio station/volume on the steering wheel .. and Bluetooth plays up. Switching off, then on the car, mostly clears the problem, although the first time, the engine warning light came on, and the dealer cleared it. Dealer said intermittents need to be shown to them when the Holden experts are available for them to consult [8-4pm]. I rang Holden... no known issues.. suggested next time it occurs, I take it to a dealer and leave the engine running.
I have noticed that when I had issues, it was when the car was parked in the street ..... ie when the car has been sitting in the sun...
Now this phenomena seemed coincidental. [the car has life under a carport] . So I tested my theory today . I started it up under the carport,
(all OK) and reversed 15 feet, turned it off and left it in the sun... 20 minutes later, started the car up... bingo.. problem happened again!!!
So I took it to the dealer, leaving the engine on. The Tech 2 [?] analyser came back with B1325 "DTC unknown code" [or something like that]
The dealer indicated they will chase it up with Holden and I will leave it with them all day later this week. They were kind enough to inform me of
the recall - back passenger seat- which they will resolve at the same time.
I fear that this problem will drag on and on !!!!
