Series II Air con performance
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Thumpin, Nov 11, 2011.
  1. Thumpin
    Thumpin Member
    top of Sydney basin
    VE II SSV Sportwagon
    After a few warmer days here in Sydney lately, I've noticed the A/C has trouble getting me comfortable. I normally leave the climate control set to 20 degrees but even if I crank it to 'C' which is the lowest it goes it pretty pathetic. Swapping between fresh & recirc doesn't do much.
    I have a digital thermometer and I stuck it in the vent and it gets the air temp at the vent down to around 10 degrees on a 30 degree day. Takes about 10 minutes to achieve this temp. My VT could get 4 degrees at the vent.
    Gone are the days of ice spitting under-dash A/C but I thought the VE's would have been more efficient than this:rant:
  2. vicarious
    vicarious New Member
    SA
    VE2 SV6 SPORTWAGON
    ii think thats what you get with the "eco" friendly gas, i have noticed that the hard plastics seem to retain heat
  3. Tonyla1
    Tonyla1 New Member
    Series ii SV6
    My Series II aircon is plenty cold enough for me here in Brisbane. I usually have the climate control set to 22 however I occasionally bump it up to 23 as it gets a little chilly. It doesn't take an unreasonable amount of time to cool down after having been parked in the sun.
  4. mr031
    mr031 New Member
    brisbane
    vl
    you might be low on gas with a slow leak, you should notice a difference on recirculate about 5c
  5. Fekason
    Fekason Fekason
    Penrith NSW
    I think it's good!
    I am more than happy with the aircon performance in my MY11 SV6.
    I also live in Sydney (out west). I park the car in the sun all day. On the hottest day (Tuesday at 37.4), I drove between 1 and 2 km with the windows open and aircon set to 22. Closed the windows and the inside temperature was better than bearable and comfortable by the time I arrived home: about 6 km and less than 10 minutes. The outside temperature was still 35 when I hopped in the car.
    Sounds like something is wrong with yours to me.
  6. Cruzer
    Cruzer Member
    NSW
    VF 2 SSV
    Mine is a quite ok usually, sometimes seems to take a while to get cold, but its fine after that, I had more of a problem getting it to heat up nicely last winter,
    seemed to never get quite warm enough.
  7. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    Take it in and get the gas charge checked, first check vent temp on recirc at mid fan speed.
  8. WogBoyz
    WogBoyz 435rkw/590rwhp
    Cairns, Qld
    08 VE SSV M6 Ute
    Ive noticed my ssv aircon is fairly shite house too for the heat up here, my old vs used to freeze the cabin up in a few mins
  9. burleighboy86
    burleighboy86 New Member
    Regional South Australia
    VE MY10 SV6 A6
    No problems here either. So far, down in SA we've had temperatures up to 35-36 degrees. I hate the heat down here too. Real dry. Give me a humid heat any day.
    My air con has not missed a beat. Cools the car down within a couple of minutes, so much so that I get too cold.
  10. Thumpin
    Thumpin Member
    top of Sydney basin
    Just my luck if its leaking.
    Today I must admit it worked quiet well. The performance of the A/C seems to vary. Maybe its a climate control problem with the system letting heater air into the mix.
    I can always hear a modulation of some vent behind the dash. Sounds like someone squashing a coke bottle. You would think when I've selected cold the vent door would stay in one position.
