Series II VN, just will not start.
1vngal
North Tassie
'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
Ok, so here's the problem:
When trying to start the car it'll just wind over heaps, and not actually fire. It sounds like it wants to, but it just won't. A couple of times it has actually fired but it's spluttering heaps for about 3 seconds then it just dies.
I've swapped the coil packs over from another VN that a mate has just sitting in his back yard. And that made no difference. So next on my list is the CAS. But I don't really want to have to replace only for it to not be the problem.
What I want to know is, what are the chances of it being the CAS? What else could it be? And is it possible to do find out if it is the CAS for sure without having to take it to a mechanic?
I just want my car going, I hate not being able to drive it...
Thanks guys.
vt1538
455rwhp LS3
55
The Dead Centre
VY SS S2 11.284@125mph
It could be many things.
First check that the fuel pump is working.
If O.K. then check that the engine has spark.
If the car has spark it will be doubtful that it is the CAS.
If it doesnt it could be the DFI module or CAS.
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Can you hear the fuel pump when you turn the ignition on and then off again?
If no sound from the tank a gentle thump to the bottom of the tank may get it going.
Have u checked for error codes?
1vngal
North Tassie
The fuel pump is working, you can hear it perfectly when you turn the ignition on. It's was only just replaced 6 months ago!
Error codes?? Nah, I haven't done that. I was fairly sure it was the coil packs, but that turned out to be wrong, so now I'm back to the drawing board....
88GreenVN
Next Exit Left
60
Surprise, Arizona
Chances are its the CAS if you have tried a corepack/DFI unit. But you should see if you have any error codes
CSL
missus (in more ways than one)
get some water, and pour it onto the Crank angle sensor, (behing the largest(crank shaft) pully, wait 30 seconds and 99% it will start, very common problem
88GreenVN
Next Exit Left
60
Surprise, Arizona
This generally applys if you have been driving and the CAS is overheating
1vngal
North Tassie
Well, when my VN first did it, it hadn't been driven for about 5 hours, (it was fine beforehand) So I guess that's ^^ not going to help??
Garth
Your guess is as good as mine......
46
www.justcommodores.com.au
100 series Toyota Landcruiser V8 monster
put hand on injectors and with a mate starting for the car you will feel the pulse, if there is no pulse, crank angle sensor.
do that and get back to us
1vngal
North Tassie
Thanks Garth, I'll do that as soon as I get a chance.
