VS V6 Serpentine Belt riding forward on belt tensioner pulley
Hi Guys,
I have recently had problems with my Serpentine Belt riding forward on my Belt Tensioner pulley to such a degree that it was partial off it. The belt had slipped off and disintegrated itself once , so I decided to replace the tensioner itself with a new one. Put it all back together and it was exactly the same.
I have read heaps of items on here about similar situations but never any fixes for it. Well I have fixed the problem and will share what it was and how to check if it is the same problem in your situation.
What fixed the problem was replacing the Harmonic Balancer. This was on a VS V6 with 250,00km but would be the same on most of the V6 Ecotec Engines that followed. If you are experiencing a similar problem, here is what to look for.
Looking down at the idler pulley between the Harmonic Balancer and the Air Conditioner pulley ( bottom & right of the harmonic balancer) you should see the belt is running forward slightly on that pulley. You should see the shiny part slightly exposed where the belt was normally running beforehand and is now moved forward slightly. It could be as little as 1 to 2mm, it was in my case. This amount of movement will show up at the tensioner pulley as being around 6 to 8mm out.
The result was the belt was riding that far forward on the tensioner pulley and was trying to be pulled back into line by the grooved power steering pulley. It was that far out that it has a very high chance of coming off and shredding. It happened to me twice and I actually caught it riding on the outer lip of the power steering pulley once about to come off.
In my case I had to also replace the tensioner pulley arm again as well, as the belt had been riding on the outer edge of this pulley for about 6 months after initially replacing it, before I actually found and had the Harmonic Balancer replaced. So when the Harmonic Balancer was replaced and the belt was riding correctly the tensioner was jumping and rattling badly. You could hear it rattling when inside the car.
Now all is well, belt running correctly in line, tensioner quiet, happy days.
Hopefully this will help someone out as it took me ages to find and fix this problem. Remember that the belt riding forward on the tensioner pulley is the symptom and not the cause. The root cause was the Harmonic Balancer even though the Harmonic Balancer appeared fine.
