wannaeatyourbrains
- Sep 24, 2019
- 591
- 544
- 93
- Age
- 52
- Location
- Mecca
- VZ Executive
Hook me up again, please chaps.
After I finished the valve stem seals, and put everything back together, I found my battery was dead flat.
I gave it a jump start, and it turned over and started up OK.
Then it cut out.
After that, turn the key to ACC, the battery light and system check etc. come on. Goes to the old 'Service Error Contact Dealer'. If I turn the key to start, I can hear the starter relay click.
But I got no power to any electrics in the car, including the OBD2 port, the starter relay, any lights etc. The key fob no longer locks and unlocks the doors or opens the boot.
No red padlock flashing on the dash, but it is like the car has been immobilised.
I checked all the plugs and earths, found the earth wire to the ECU a little loose, not much. The wire to the back of the key ring was a little loose too, cause I just replaced the key barrel. Fixed all that. Earths are all earthing OK.
Key fob battery is still giving out 2.98 volts, the battery 12. Hooking up with the jumper leads to another car doesn't help any.
Any suggestions? What have I missed during reassembly, I wonder? Thrown the wiring harness around too much and done something there? Where to start looking?
Then it cut out.
