Service Vehicle Soon Warning
commodore665
expat Saffa
52
New Zealand via Cape Town
2005 SV6 & Alfa Romeo 156 V6
hi guys , today while pulling into the supermarket , had just backed into parking space , the SVS warning appeared , so when I re started the warning re appeared on the car I pressed the mode button and the warning went away and the SVS light was on on the bottom of the screen , so after a few seconds of driving the SVS light went away , but the warning appears when I start the car but does go away after I do the preceding steps , I'm thinking oil pressure sensor gone haywire, hope that makes sense
dans_vz
Swan Hill
MY16 VFII SSV Redline Manual & MY13 VDJ76 Cruiser
I had similar issue in my old VZ, it was the oil pressure sensor. You can confirm with a scan tool
commodore665
expat Saffa
52
I'm going to get it looked at this week , comes on while car is idling too . thanks for your reply
Fu Manchu
WA.
Slug powered VZ, Cross 8 VZ, VE Calais & ya mum.
It’s a cheap sensor to replace. Easy as well.
commodore665
expat Saffa
52
are they able to be cleaned , rather than replaced ? I’m guessing there is no way to check either if it’s buggered ,if you don't have the right equipment
Fu Manchu
WA.
They cost like $30 and take 5mins to change.
Fu Manchu
WA.
Did you see the timing chain post by the new member? Was fully sick.
De-gummed the engine with some ballsy methods, that do make logical sense looking back at it and proof it works without side affects.
commodore665
expat Saffa
52
Didn’t see that one , I’ll do a search day some point, just read it bbq cleaner sweet , who’d have thunk it
commodore665
expat Saffa
52
Quick update. , just had the check oil warning on dash , level is fine , I’m guessing if sensor is toast I’ll give a false warning
