Setting L3 V6 Temp Gauge to V8
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by 88GreenVN, Apr 1, 2010.
  1. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    I've got the upgrade V6 L3 cluster to V8 bug real bad. *sigh*.
    THe tacho conversion is all under control. Now for the temp gauge..... I have adjusted the gauge to read higher by using the slider adjuster on the back and it looks to have worked some what. Normal running temp is almost the same as my V8 gauge. So I could probably sneak a little more on the adjuster to get it very close
    Now the pic the v8 and v6 settings have ohm reading and point on the gauge as to where the needle should be in relasion to the ohms.
    Question: Are the gauges so different that the readings would be out to such a degree that the car could overheat without the gauge reporting this back. That is running a V6 gauge and adjusting it up.
    A V6 gauge reads much colder than the V8 unit when in a V8 car.
  2. Shearer
    Shearer Member
    VY SS ute
    This quote is from the factory VR-VS manual CD may be of interest :idea:
    Does this mean V8 gauges after the date are compatiable with V6?
