Severe Wheel Issue
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by MacleanMan, Dec 4, 2012.
  1. MacleanMan
    MacleanMan New Member
    VT Acclaim
    Hey guys wondering if any of you could help me out here, I lost control in the wet last night and mounted the curb. This is the result, can anyone tell me if it's beyond repair or what I should do etc?
  2. Tree cutter
    Tree cutter Tree cutter
    Mt Gambier SA
    VX Calais SuperchargedV6
    Does the wheel wobble when you turn it around when it is jacked up or is the wheel permanently leaning out at the top. I f the wheel wobbles then it is probably just a bent wheel so just bolt the spare on and get another wheel from the wreckers. If the wheel is permanently leaning out at the top then you have bent something in your rear suspension.
  3. Big-Al
    Big-Al Banned
    Aussie and proud
    VY SS 5.7 M6
    it's fixable but i reckon you have bent the lower control arm at the very least. probably shouldn't have been driving like an ass.
  4. LordEthan2
    LordEthan2 New Member
    Australia Victoria
    VX Executive S2
    Well firstly i wouldnt run the risk of driving it to where you need to go to fix it either, i would jack it up mate take the wheel off have a real close look and take a few more photos for us so we can really see what your dealing with, but as is ... Doesnt look pretty LOL.
  5. CONROD
    CONROD Member
    SOMEWHERE in the land of OZ
    VZ SS THUNDER 6.0l 6 Sp
    mate you are the one who can physically see where and what the damage is!!!! You have done some good damage to something in the rear end,the wheel would be the least of my worries.:banstick:Looks like its still holding air ?
    If you cant see anything bent by comparing it to the other side,take it to some one who can
  6. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    X2 for this or bent the sub frame.
    PJDM1980
  7. Cashman_309
    Cashman_309 Member
    VTII Calais
    You will need:
    Drivers side rear lower control arm assembly (with wheel hub)
    Rear shock absorber
    A wheel
    5 wheel nuts.
    Bolt that all up and get a full alignment. A cradle alignment may also be required.
  8. zersys
    zersys Bolt Snapper
    VY Berlina Series II/BMW '02 E39 530i
    Very hard to tell mate, as mentioned take the wheel off and look, compare to the opposite side. And post some pics from all angles too.
    I could be wrong, but my other concern here is the diff too, looks like a very hard side on hit. Imagine impact straight into the diff gears via axle shaft, no good.
    Tbh before buying replacement parts I'd take it to somebody who knows what they're doing, and most importantly somebody you can trust! With something like this a mechanic can have a field day.
    But like others have said as well, good chance the lower control arm is likely bent.
    Good luck with it mate.
  9. Mick1988
    Mick1988 W.A. Cruise Moderator
    Perth, Western Australia
    Too many to list......
    My first wagon I bought from an auction with the same damage for $600. Replace the entire complete rear cradle with one from a VX II, VY or VZ and replace that wheel.
  10. jughead1
    jughead1 New Member
    Central Coast
    VX Commodore Executive
    Without knowing the circumstances of the accident you are condeming him for "driving like an ass"???
    Around our place the roads get VERY slippery after it rains. I do not "drive like an ass", yet have skidded many times, sometimes going as slow as 30 KmH!
    My wife has had a bad accident when the car skidded, and she was only doing around 40 KmH!
    So, give advise (which is what was asked for), but don't comment on driving style without anything to base your assumptions on!
  11. s_ikari2015
    s_ikari2015 Fun IS easier with an 8
    Australia
    '02 Monaro V2 CV8, '83 Subaru Sherpa, '87 Sherpa
    op said it was at night, also, so it's difficult to see an oil patch on a wet road at night on a corner.
    I agree that the first thing you should do is jack it up and remove the wheel. Note how the suspension expands and the wheel moves as you jack it up, might give some insight into some damage. Then more piccies and look for parts where paint is cracked and dirt has worn off etc. An old dirty part that is damaged can sometimes be easily seen... it's "cleaner" where it bent.
  12. monkeys437
    monkeys437 New Member
    Mornington, Melb
    VS Stato l67
    It looks like suspension damage. I'd be hoping the rear control arm is all that's damaged, you might get away with replacing that which isn't any big deal. If the whole rear subframe it bent that's quite a big job as the diff needs to be dropped.
  13. imrhoss
    imrhoss Member
    1996 VS Statesman, 2013 VE II SV6 Thunder Ute.
    Similar thing happened to me, except I hit a traffic island (stupid, I know). I took it to pedders and paid $14.95 for a full check up. Apart from a $4000 repair quote they told me my front strut was bent. $30 later at the wreckers and it was fixed.
