Shaking at Idle
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Turd Ferguson, Oct 7, 2011.
  1. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    O.k so the other week i noticed the Stato was starting to shake at idle whenever i was stopped at the lights, its being getting worse so i changed the spark plugs and leads but now its no better and it feels like it has a miss.
  2. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
    Could be shagged engine mounts.
  3. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Check which cylinder has the miss by removing each lead one by one from their coil. The one that makes no difference to the idle will be the culprit. If they all make the idle worse, then it is most likely a TPS or fuel issue.
  4. Sean880
    Sean880 Well-Known Member
    VIC / NSW
    2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
    Which grade of fuel have you been using in the car over the past year? E10??
  5. Turd Ferguson
    N.S.W
    Disco
    Ive been running BP ultimate since I bought the car
  6. Turd Ferguson
    N.S.W
    Disco
    I let the ECU reset by taking off the neg power to the battery today and its been running fine.
