[General] SHaving and painting rocker covers
Discussion in 'Holden Commodore How-To's' started by seq4x4, Jul 7, 2012.
  1. seq4x4
    seq4x4 New Member
    Sunshine Coast, Queensland
    VS
    So i got bored at about 2am this morning and went hunting for something to do. The things i came up with required power tools or parts i didnt have yet. So i look in the corner and find some old rocker covers. I then started to think, what could i do to these to tidy them up. As i only had some colors i thought i may as well paint them up for my mates wifes wagon as it lacks customization in the engine bay. So i got to work.
    I got some body filler and started filling in the dents (from the chains) and the groves. I learnt afterwards less is more. The amount of sanding i had to do due to the thick application and the parts that didnt need bog took forever.
    You will want to do a light sanding. Meaning getting close to the finished sanding product and check for air bubbles. I found a few and had to do some more bogging to make it smoother.
    Then youll want to smooth the whole thing out and check to see if everything is flat and your happy. If so, to the next step. If not, ad more bog and go again.
    I bought some primer filler awhile ago from super **** auto. It was their branded stuff and it is horrible to use. I did 2 coats with that and then 1 coat with normal primer then smoothed it. Then added another coat of normal primer (K&H i think the brand was) and smoothed it again.
    Because im going with a bright shinny color such as Anodized Purple, i needed a light base coat. So i did some searching and found my white under coat. I did 3 coats of this then smoothed it. Youll want to do light coats, not thick ones. You want to slowly get coverage not in all in the first coat, otherwise itll be thick, takes forever to dry and more then likely to get runs in the paint.
    Now that the base coat has dried and been smoothed. Time to lay the color on. The same deal applies. Light coats to slowly get coverage.
    Then you get the end result. Its a much neater look in my opinion.
  2. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    Looks good, I've been thinking of painting
    mine, but hadn't thought of filling the
    grooves. 2AM? Do you know Neville
    Bartoss?
  3. Wombles
    Wombles Cars cost too much.
    Wonder how long that would last.. Looks good though.
  4. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    Do you reckon the filled parts would
    crack? I wondered that
  5. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    Are they the plastic rocker covers or the alloy ones?
  6. Wombles
    It looks like the plastic ones..
    Yea. I reckon they'll crack.. Or the bog wont handle the heat.
  7. GothicKidd
    GothicKidd ლ(ಠ益ಠლ
    South Australia
    VR S2 Exec
    Defiantly trying this out.
    I've found out, My girlfriend knows how to use bodyfiller better than what I can... Great.
    Anyways. I'll get some pictures once I've finished. :p
    edit:
    This is my attempt at it, I'm a cheapo.. I didn't use Primer. Not pleased with the results but eh.
    I'll give it another sand back and repaint I recon.
  8. seq4x4
    seq4x4 New Member
    VS
    Itll handle the heat. Because you dont get too much heat on the rocker covers it will be fine. Some people even do this on intakes as well. Im even using heat resistant paint as well, well, just because i can. Their just the standard plastic ones. As im sick at the moment im sleeping alday so i have enough energy for work at night. So i didnt get any daylight photos and the other one is still covered in unsanded bog.
  9. Wombles
    Wtf did you use Gothic?
  10. pjdm1980
    Geelong, Victoria
    Play doe??
  11. seq4x4
    seq4x4 New Member
    VS
    Come on guys, everyone has to start somewhere and this could possibly be his first attempt at doing this sort of work.
    kyalkk likes this.
  12. GothicKidd
    GothicKidd ლ(ಠ益ಠლ
    South Australia
    VR S2 Exec
    I used the same stuff seq4x4 used.
    I didn't sand it back enough, I'm not pleased with the results. but yeah first attempt at using bog aswell.
    Plus that photo just makes in look bad... :p
  13. kyalkk
    kyalkk Donating Member
    riverland
    vt s pac
    might give this a go one day, and i have painted mine with out high temp paint and it has never had any troubles
  14. pjdm1980
    Geelong, Victoria
    Only have a laugh I'm sure he took no offence.
  15. seq4x4
    seq4x4 New Member
    VS
    New finished photos added. Still sanding the other one. Been at it for 4 hours trying to get it perfect. Im doing it by hand too..
    Gothic, patience is the key. Like i said, 4 hours on this one and the photo shows how far i got. I am doing it by hand tho. And im trying to make this one perfect as this one is more noticeable then the other. The black lines where just to remind me of the areas that needed to be re bogged as i went for some food.
  16. someguy360
    someguy360 Well-Known Member
    Adelaide Hills
    Might give it a try at some point, got heaps of bog left over from my VS rebuild
  17. Drawnnite
    2000 Vs Ute
    how does the bog stand up to the heat from the motor?
    looks good though.
    tempted to give it a crack with the spare pair sitting around.
  18. seq4x4
    seq4x4 New Member
    VS
    The bog will withstand the heat. Its been used on manifolds for a long time. Using none temp resistant paint will also hold up against the heat as well. As these parts dont get too hot. I even set a piece on fire and let it burn for about a min, still didnt crack, just turned black.
  19. someguy360
    Adelaide Hills
    Bog will be fine with the heat, (get a K&H filler or similar brand, I have found the cheapo stuff can tend to fall off/crack)
    Get some high temp enamal paint (can pick up a spray can for around $10-15 from repco etc)
    I got some Holden Red when I did my rocker covers.
  20. GothicKidd
    GothicKidd ლ(ಠ益ಠლ
    South Australia
    VR S2 Exec
    Well, I've looked at the situation.. Thought what a mess I've done with this 'playdoe'. - I think I put more than enough bog on it... so.
    I sanded it back and it's looking so so much better than the first time I did it. when I get some time and when it's not so cold I'll get around to finishing it.
    But I recon this time It'll turn out better.
    That purple looks great, Got any pictures of it in the car?
