shift kit
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by bennYC, May 12, 2008.
  1. bennYC
    bennYC VXTASY
    VX Berlina
  2. chargedvx6
    chargedvx6 Active Member
    VY SII HBD Calais L67
    That is not a shift kit IMO. It changes the resistance in the signal going to the line pressure solenoid. Might not do damage but it isn't a kit all the same.
  3. chargedvx6
    To add to the last post, a hard parts shift kit removes pfysical restrictions in the tranny and adds more efficient, reliable parts to it as well. If you only up the line pressure without increasing the port size of some major galleries the pressure could reach a point where it encounters restriction and increases heat.
  4. Trewman
    Trewman New Member
    VF SSV
    These things are useless. Had one in my vt. Only shifts hard when you are going very slow.
  5. bennYC
    bennYC VXTASY
    VX Berlina
    thought that may be the case
    i will have a look into the hard parts shift kit
    cheers for the replies
