Shift kitted vx ?
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by jordazbro93, Oct 6, 2012.
  1. jordazbro93
    jordazbro93 Banned
    wonthaggi
    VX Executive S2
    Hey guys im thinking about getting my car shift kitted , of heard that it improves gear change and so on.
    I would love more info . And does it shorten the gearbox life ? in a years time i dont want to be paying 600 for new gear box .it is a auto .
    And i seen a add 195$ installed.
  2. Ghost
    Ghost Donating Member
    Junee New South Wales
    Vs Commodore berlina Sedan 1996
    Shift kits are designed to protect the transmission so it's probably worth it only thing I'm not certain on is if the shift points have to be changed
  3. TI3VOM
    TI3VOM Active Member
    Here there and everywhere.
    VT Commodore
    Trans-go stage 2 shift kits are a good choice, you will be paying around $190 for the kit alone.
  4. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Holden gearboxes are notoriously lazy shifters. A shift kit will help dramatically and an external transmission cooler if you don't already have one. Not every shift kit does the hectic 1-2 chirp either.
  5. jordazbro93
    jordazbro93 Banned
    wonthaggi
    VX Executive S2
    Just want that non lazy change haha want it to change nicely. And does it stuff your diff?
  6. Ghost
    You shouldn't have any problems with the diff providing the engine is pretty stock but if you go super charging it then you may need to upgrade the diff
  7. auzzie_bradd
    auzzie_bradd Member
    GC, QLD
    VX ss
    Im glad i stumbled across this.. Is any of this illegal for a p-plater? Probably a stupid question but yeh.. Thanks :)
  8. FATMOE
    FATMOE New Member
    VY Clubsport R8
    No it is not
  9. vx_commodore
    vx_commodore Member
    Sunshine Coast QLD
    VX Commodore 'S
    A shift kit is a great idea for these box's IMO.
    I had a TransGo stage 2 fitted to my Gearbox, Love the result's.
    Well worth the money.
    Firm's all the shift's up, Not so lazy anymore.
    You should also consider getting a Corvette Servo fitted, Firm's up the 1-2 shift, This will make you chirp 1-2 if you are into that.
    As far as i have gatherd, It's alway's a good idea to fit both together, It will cost you around $20-30.
    One thing people have to consider is the condition of there box.
    If you're current box is tired and worn, High K's ect, Then it will not be the best idea to fit the kit, You will just be wasting money.
    My box had 80k on it when i fitted mine, Still going strong!.
    The only thing's that will cop a floggin, Is further down the power train, Ie, Tailshaft, Diff.
    If you thrash it everywhere, It won't last long.
    Treat it well, And you will have many year's of happy motoring!
    TransGo is the way to go.
    Don't bother with B&M
  10. jordazbro93
    jordazbro93 Banned
    wonthaggi
    VX Executive S2
    How much for corvette servo fitted ?
  11. The1
    The1 A Memcal a Day Keeps..
    QLD
    VS V6 Berlina Auto
    Or you could get a tune done for firmer shifts and less slip, plenty of gain in the tune side via line pressure and pressure gain while shifting, the standard shift patterns can be improved to, while your there get the engine done to!
