Shimming of roller rockers
keith reed
76
Raceview Qld
1983 vh v8 sle 2000 vs v8 ute 2012 ve11 redline
When I pulled the motor apart on my vn v8 I noticed that the roller rockers had been shimmed. The heads have been planed 80 thou. Is this an acceptable practice?
07GTS
Australia
VEGTS BUILT BLOWN E85
sometimes they have to be shimmed so the tip is central and stays closest to central on the valve during movement
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
yes... says that someone took the time to check your valve train geometry
as I do when i build a new race engine :)
keith reed
76
Raceview Qld
Thanks for the help. I have had a lot of bad work done on this engine over the 21 years
I have owned the car and thought this was just another example. I'm glad I asked.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
Depends they could be shimmed to fix valve train geometry or could be just to save buying shorter pushrods panties and the geometry could be all up the waazoo investigate further I reckon
