Shock Question
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Chirpstr, Oct 18, 2007.
  1. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    G'day, some may know of a shock that goes off to one side on the bottom mount. I know this is normal for shocks but what side does it go? I have it on the tyre side, the same on both sides... Does it actually matter as long as they are both the same?
    Cheers.
  2. Chirpstr
    like the mount on the bottom of shock goes out to one side...(only a bit)
  3. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    If the bottom of the shock is offset, the offset side goes on the pin first. This spaces the tube away from the mount.
    l l
    l l < shock
    l_l
    -lHl== < mount
    pin ^ on car
    If you can understand that.
  4. Chirpstr
    ahhh so looking at the pic I have done it right. Comes down then goes towards the trye
  5. Chirpstr
    unless you look at it from the front of car...then it may be the other way...
  6. Panama
    Panama Member
    '87 VL Calais with L67
    there is a machined down spindle that fits into a socket on the irs model of vs's
  7. Chirpstr
    Ok guys, if I don't have bearings in the struts will it damage them???
