Shocks/front shock bar.
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by jordazbro93, Oct 3, 2012.
  1. jordazbro93
    jordazbro93 Banned
    wonthaggi
    VX Executive S2
    Hey guys im looking at changeing my front shocks and i need to get the bar off that connects to the front shocks . Im wondering what size bolt it is ? the one of the top . i have used 15/17 mill no go .
    And wondering what size i need to take back shocks off aswell the bolt in the boot.
    Please heap this thing is doing my head in .
  2. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    That bolt should be a 12mm or 13mm, why have you got the spring compressor on while it's in the car?
  3. jordazbro93
    jordazbro93 Banned
    wonthaggi
    VX Executive S2
    O this is just a picture I it offnet
  4. TI3VOM
    TI3VOM Active Member
    Here there and everywhere.
    VT Commodore
    Are you sure about that?
    I mean, wouldn't you just jack the car up and see for yourself?
  5. jordazbro93
    jordazbro93 Banned
    wonthaggi
    VX Executive S2
    Yeah true ended up loosening the bolts. But the bottom joint is stuck tryes everything won't come out. Any ideas?
  6. Mick1988
    Mick1988 W.A. Cruise Moderator
    Perth, Western Australia
    Too many to list......
    Angle grind the nuts off? Depends on what sort of sway bar links you have I've seen 12mm, 13mm, 14mm and 17mm nuts on them lol. Use a small spanner to hold the rod (there should be a slot for you to hold) while you undo the nuts.
  7. jordazbro93
    jordazbro93 Banned
    wonthaggi
    VX Executive S2
    Yeah I ment the away bar is jammed got off the bolts out just bottom joint wont come out
  8. Mick1988
    Lever it out with a crow bar or flat blade or tap on the thread with a hammer. Surely you're going to put new sway bar links on so wont matter if you damage them.
  9. jordazbro93
    jordazbro93 Banned
    wonthaggi
    VX Executive S2
    Haha yeah tryes that smashed it with a hammer lol did not move
  10. theghostoftime1978
    theghostoftime1978 New Member
    canberra
    99 vt berlina series 1 V6
    you can put a bar between the radius rod and the swaybar so it will push sway bar down enought to slide the link pin out, will probably have to do it again putting the new link pin back in.
