shocks/springs question
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Nic92, Jan 6, 2012.
  1. Nic92
    Nic92 Active Member
    WA
    2005 Mitsubishi Evolution 9
    Hi guys,
    just wondering, transfering the springs from a VY S to a VY Clubsport, is it possible?
    or would i need to buy new ones?
    also can i use the shocks from the vy s?
    thanks
  2. vn1989
    vn1989 New Member
    maryborough
    vn executive series 1 v6 1989
    id say so there both irs. but the front spring are 2 suit v6 and u wanna put them in a v8 so it would sit lower and the front would be softer but would fit. but the back would be a straight swap
  3. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
    The LS V8 engines and ecotec V6 in VT-VY's in most cases use the same front springs as they are similar in weight.
    In the early VT the Holden V8 was 40kg heavier than the ecotec V6 so then there were different rate springs.
    So using your old springs shouldn't be a problem.
    HSV shocks are slightly better than Monroe GT Gas (not Sports), what are the shocks from your old car.
  4. Nic92
    Nic92 Active Member
    WA
    they are Bogue Turbo (damn service place put them in when i gave them the springs to put on)
  5. Surfwagon
    Sydney/NSW
    As for the springs usuing thiose shocks shouldn't be a problem and if you liked how it rode and handled in the Spac then should be the same in the Clubby.
    The Clubbies (infact all the HSV's) are slightly heavier than equivalent Commodore sedan but all over not just in the front like in the early VT series1.
    The extra weight in VY's comes from things like full body kit, bigger brakes if fitted, bigger front swaybar, extra interior gear.
    As they all the little things added together make extra weight.
  6. Nic92
    Nic92 Active Member
    WA
    yeah thanks for that :)
