Short Shifter
wes
65
brisbane
VT SS 5 spd man.
Need some info on short shifters.....The length on the stick from the pivot ball to the top is shorter....but does the length from the pivot ball down to gear linkage alter ??..
_R_J_K_
Zenki S14
Yes. A word of warning though, some people like them, some people hate them. I hated, hated, hated mine.
STEALTHY™
So Wet For You!
SA - The Roadworks State
I love love love mine :D
Drawnnite
Obviously Unsensible
2000 Vs Ute
all depends on the short shifter if you want to get technical.
some may call cutting the shifter length down as a short shifter (technically you could say there is a shorter throw/movement between gears)
some may have a different pivot as to which the gearstick stays the same height but has to move less
and theres probably a few that mix the 2 together.
think of it like a lever or bar such as a crowbar. lifting a box
you can put your hands halfway along. more effort but shorter distance to cover.
further away longer distance but less effort.
then add in say a pipe and move it along to see varied effects.
to answer your original question.
it depends on which short shifter and if its a home dodgy job (read chopped down) or one that's been designed to act differently.
VN SSer
cairns
VN SS
does the box need to come out to replace the shift lever. or can u install the short shifter the the gear stick hole? on a T5 vn
cander24
NSW South Coast
VZ GTO. VS LS1.
On a T5 you'll do all the fitting from in the cabin through the shifter hole in the trans tunnel.
Nut Kracker
Donating Member
61
Echuca Vic.
VT SS 304ci (195i)
What about on the VT Getrag 5sp, same?
