Mate,
I just reread a few of your posts... some revised comments below:
:: With regards to the bonnet, you could shop around for better prices, you could could do it yourself (its hard but if you are willing to learn it can be done) or you could try and find one of those wonder products at Supercheap or your local auto stores that claim to fix faded paint. There are also products/waxes that will resist fading.
:: With regards to the fuel pump, what makes you say it is on its way out? Mine is quite loud when priming the fuel, and has been since the day I bought the car. You might be freaking about nothing.
:: Again, power steering pump AND rack, why do you say this needs to be replaced? You said it hasn't had a service in a long time? Is it leaking? It could be something simple like the washer or the fluid level.
:: Full service - What exactly needs attention in the service? You may be able to do this yourself for much less:
Generic oil & filter - $35
Clean air filter - $0
Generic spark plugs - $25
Fuel filter - $25
Do you have a Gregories manual? Its the best $40 investment you could make. This will tell you what you need & how to do everything above. I saw in your other post you said that the driver side door handle is loose? Well so is mine, you just have to remember that this car is 7 years old, so it wont be perfect. If you are really picky you could pull the door skin off & inspect... Again this is covered in the Gregories manual.
Hope this helps...
Fuel filter - $25
Hope this helps...
