Should my plenum look like this?
Discussion in 'VY Holden Commodore (2002 - 2004)' started by looks450, May 5, 2012.
  1. looks450
    looks450 New Member
    VY Crewman
    I am chasing a rough idle and took the top off the plenum and it was fairly stained. I am just wondering if it should be like this.
    I should at this point I add that the car has an in-line valve lub system attached. ImageUploadedByTapatalk1336220472.428858.jpg
  2. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Yep normal for the ecotec. Could give it a clean but it will only be dirty in a couple months any way. Clean your idle air controller and go from there.
  3. Dr HaxZaw
    Dr HaxZaw New Member
    R34 GT-T
    if your chasing a rough idle definitely clean the idle air control valve... cleaning the plenum will make it run smoother as well
  4. VYMAD
    VYMAD SILVERFOX
    BUNDABERG Q
    VY EXECUTIVE S2
    That plenum chamber looks normal. In fact even cleaner than mine when I had it open to clean.
  5. HERONVY
    HERONVY New Member
    Steel city
    2003 VY2 SS
    do what i did yesterday to mine, pull it off and clean it out with kero, wire brush and wire wheel on an air drill until it shows the bare aluminium again
    clean the IAC as mentioned
    then fit a catch can to stop most of the oil from the crankcase gas getting in there via the t/b
    take a look at your t/b aswell , more than likely itll have sludge on the butterfly too.
    Clean that off with kero and toothbrush + wire brush
    Sent from my GT-S5570 using Tapatalk 2
