Showing Speed on dash in vr
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Joey_21, Mar 15, 2007.
  1. Joey_21
    Joey_21 New Member
    Western Suburbs
    VY SV8 HBD---mmmm LS1
    my mate was tellin me that u can get ur speed showing on ur dash in my vr calais he said where u usually set the speed u can reprogram it or sum rubbish 2 show ur actual speed ive never heard of any1 doin it has any1 else heard of it?
  2. TheForgotten
    TheForgotten only human......
    quarantine
    VR EXEC
    not sure it'd work on a calais, but on the lower spec models, hold both up and down arrows while turning the key to start the car.
  3. Chilli_Red
    Chilli_Red Member
    Brisbane, QLD
    2000 VX XU6
    I tried that today in my bros new vr2 acclaim but it didnt work. i have a feeling the speed alert my be buggered though
  4. Harvs82
    Harvs82 Active Member
    Glen Waverley VIC
    MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
    You can get your speed shown in the digital readout on the bottom of the dash by pressing and holding the SET button whilst turning the ignition to ON.
    This will display battery voltage amongst other things, and you simply press MODE to scroll through, and I'm pretty sure that one of the readouts is your speed. You will loose all the other trip displays whilst running in this mode, you will need to turn the ignition OFF to reset back to the standard displays. If you really want to see the speed each time you drive the car, you will have to go through the above process.
  5. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    if you have the speed alert in your car you can permanently set it too a speedo without the light flashing to do:
    1. hold all three buttons
    2. start the engine
    3. hold buttons untill 100 is displayed
    4. release all buttons and hold set until the fuel light in dash disappers and speed alert is set to 0km'h
  6. TheForgotten
    quarantine
    VR EXEC
    ^^^ that only works on certain models
  7. dufus
    dufus Donating Member
    rickshaw
    In mine, i have to hold set and the two directional buttons while i start it, then i get the digital speedo
  8. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    VE OMEGA 3.6L Dual Fuel
    Is it reversable?I mean can i set it back to speed alert mode?
  9. Jon Z
    Jon Z New Member
    QLD
    97 VS Series 2
    it locks in the speedo mode if u hold all 3 buttons. The next time you start do the same and it will reverse the process and it will function as a speed alert again, if that fails disconnect the -ve lead of the battery.
  10. andyman
    Orange, NSW
    yes it does, resets back to speed alert if you disconnect the battery too
