D
devilly
Guest
02 sensors something electrical as it can't be driveline if doing it when stationery can't be brakes or rotors. have you checked the brake booster rubber and the check value. I used a heap of gasket goo around the rubber on the check value. Egr also springs to mind maybe give it a few hard revs to clean it all out. injector cleaner and run it at high revs for a bit could just be stuff that needs a few hard revs to remove. how does it idle if you remove the iac plug then the tps plug. you could also check the l/h. maybe post a video hope you find it and get it sorted out.
