*Sigh* Front Tyres Scrubbing on Struts...
AirStrike
91' VN SS
Have you had a wheel alignment? There is no need for coil overs. My mate is running 20x8.5's without coilovers. Coil overs range from $600-1000+ Depends on the strut you use, the springs, if they are adjustable, etc, etc.
AirStrike :air:
1991_Vn2nV
Gumeracha, Adelaide Hills
91 VN Berlina & 03 VY Berlina
Have you had a wheel alignment? If you havent im locking this thread and banning you:whistling :p
AirStrike :air:
lol...im just gonna say yes... I had one like 3000km's ago on the front after some bastard medium strip moved in front of my car at 4am in the morning and blew my tyre :p So I doubt its off by much if any, and its booked in for another on Friday...
p.s. Dont ban me :p lol
MaN|aC
VT 4.2 S/C
go down to Pedders Morphet Vale where I used to work because they actually do wheel alignment properly where they actually adjust your camber and castor not just the toe
to get a descent wheel alignment in Adelaide is very hard to find
AirStrike
91' VN SS
That alignment was for the 16's tho. Trust me, I had an alignment on the SS with the 15's and 3 weeks later when my 18's went on I had another.
The toe was out by 1mm, camber by 10' and caster by 10'. All of that just from changing rims.
AirStrike :air:
1991_Vn2nV
AirStrike :air:
Ahhh cheers man :) Wheel alignment it is :D
What exactly is a laser wheel alignment?
Maniac and Airstrike, thanks heaps :) Very helpful
MaN|aC
VT 4.2 S/C
yep bigger wheels will give you more castor and negative camber so this will jump the toe out by a fair bit.
and you say what exactly is a laser wheel alignment?
with wheel alignment machines these days they are all lasers much quicker and it gives you more accurate reading which is good because my average doing wheel alignemnts are 15 minutes and I do 10-15 wheel alignments daily. I also use the Beissbarth microline easy 6 heads machine.
AirStrike
91' VN SS
The laser is just what they use to mesure the angles and dimentions. More accurate then the old version (used to bolt to the hubs).
I would start with a wheel alignment. Make sure you go to pedders or the like, steer clear of bob jane, etc.
AirStrike :air:
MaN|aC
VT 4.2 S/C
least you didnt say Beaurepairs or Goodyear which is the same company airstrike :)
xcop5l
4th year spanner spinner
ol' geelong vic
VN ex cop 5L
tyrepower probably fitted your rims seen they rub took them bac off so you couldent take them bac even if you wanted 2
