Simple question about nut size
LatinDancer
66
VY Series 2, 3.8 Executive
I have a 2004 VY series 2. When I unscrewed the nuts holding my transmission cooler hoses onto the radiator I found that a 19 mm spanner was really quite loose, but an 18 mm was too small to fit.
Surely they are not imperial ? I cannot see a comparable size slightly less than 19 mm in a conversion chart...
_R_J_K_
Zenki S14
Plenty of imperial fittings on a Commodore. Engine is American after all. Even on the VE which was ground up developed here there are 2 or 3 imperial bolts I believe.
Trevor loves holden.
vs commodore
Its like there harmonica balancer bolt its the same, 47/64 is the size but we don't have that here in Australia, 3/4 is to big. I would use a shifter wrench if it fits in.
LatinDancer
66
Hmmm....OK, so what type of Imperial do they use on GM vehicles in the States ?
The next size down is 23/32 which is equivalent to 18.26 MM...
_R_J_K_
Zenki S14
Ummm... all of them?
Can you not just use a shifter to tighten these?
ant797
bunbury
vy s
Pretty sure it has something to do with the fact its a hydraulic fitting i think most gas fittings are imperial to
_R_J_K_
Zenki S14
^^^ This is also correct. AN, JIC, NPC fittings etc.. are all imperial based AFIAK.
bazagorokan
69
central coast NSW
VE S2 CALAIS 2012, A6, 3.6
All you can really use is a fairly small shifter spanner , maybe 150 mm long that makes it easier to access the fitting . another idea is to carefully file an open end 18mm spanner to fit the fitting.
vs commodore
Or buy some shimming paper and build it up, I use coke can to remove the slack. A couple of wraps or just one might do the trick.
