simple yes or no please people
nmd_nathan
vs wagon
hey people can a blow off valve be used with a super charger
Bax
Projecting
37
QLD
Nothing
yeah..
its creating boost/ extra pressure.
as soon as the tb closes it needs somewhere to go.
Torquen
Boost FTW
Perth, WA
450+ HP FORD XR6T
does it actualy do anytning? or just a 'wank factor' mod?
stocky
34
read the post above for your answer
VLCrewman
VB\VL Crewman
Not too sure it'd do much on a supercharger, but the idea on a turbo is to stop the built up pressure running backward thru the turbine and, in turn, spinning the turbine backwards and causing undue stress on the turbine wheel. It is wank factor for a lot of ricers, but, it all depends on how big the turbo is too.
grigor
VS Executive, R31, R33
Bov
The BOV is to stop reversion, a bit like shock waves from the air flow slamming into the throttle plate.
A BOV will sort the problem and maintain the turbo rpm through gear changes.
You need to check your engine management though. If it's AFM based, you'll need a plumb back BOV.
MAP sensor based engine management could vent to atmo.
Torquen
Boost FTW
Perth, WA
450+ HP FORD XR6T
hmmm, ok so how does having one on a super charger greatly benifit performace wise...as there is no chance of "reversion" is there?
Patrio7
3Y3 K4N 5P33K 1337.
35
Perth, Como
'96 S1 VS Exec
1991_Vn2nV said:
Do supercharger blow off valves make a similar noise to the ones on turbo's? Or not?
its dependant onf the valve, some just make the whoosh others make the
hiss-hiss-hiss-hiss type noise etc
