Simulated VN VP VR, V6's
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by greenfoam, Jul 20, 2006.
  1. greenfoam
    greenfoam New Member
    VP Executive R-spec
    Took me a long time to do these, If you have one of those magic almost perfectly builts VN/P/Rs and perfect traction this should very VERY close to its real life potential. I don't normaly run the stock engines right through the simulations to see what they can do, just to see what mods give the most power per dollar. But anyway I was bored :p
    Simulated stock Commodores
    Thu Jul 20 06 12:12 am
    Time Slip For:
    VR Executive Auto
    RT .500
    60 ft 2.473
    330 ft 6.578
    1/8 ET 10.038
    1/8 MPH 72.43
    1000 ft 13.024
    1/4 ET 15.589
    1/4 MPH 87.28
    0-60 MPH 7.214
    VR executive Auto 1347kg+75kg driver
    Stock Tune 91 octane
    Thu Jul 20 06 12:26 am
    Time Slip For:
    VR Executive Auto+optimal spark
    RT .500
    60 ft 2.403
    330 ft 6.455
    1/8 ET 9.874
    1/8 MPH 73.29
    1000 ft 12.827
    1/4 ET 15.368
    1/4 MPH 88.16
    0-60 MPH 6.944
    Optimal Tune 98 octane
    Thu Jul 20 06 12:45 am
    Time Slip For:
    VP Executive Auto
    RT .500
    60 ft 2.444
    330 ft 6.514
    1/8 ET 9.945
    1/8 MPH 73.00
    1000 ft 12.911
    1/4 ET 15.462
    1/4 MPH 87.79
    0-60 MPH 7.044
    VP executive Auto 1301kg+75kg driver
    Thu Jul 20 06 12:52 am
    Time Slip For:
    VP executive optimal tune 98 octane
    RT .500
    60 ft 2.398
    330 ft 6.444
    1/8 ET 9.857
    1/8 MPH 73.36
    1000 ft 12.810
    1/4 ET 15.352
    1/4 MPH 88.15
    0-60 MPH 6.911
    Thu Jul 20 06 1:02 am
    Time Slip For:
    Vn Executive series 1
    RT .500
    60 ft 2.439
    330 ft 6.520
    1/8 ET 9.963
    1/8 MPH 72.76
    1000 ft 12.937
    1/4 ET 15.494
    1/4 MPH 87.58
    0-60 MPH 7.093
    Thu Jul 20 06 1:05 am
    Time Slip For:
    VN executive series 1
    Optimal spark
    RT .500
    60 ft 2.414
    330 ft 6.489
    1/8 ET 9.929
    1/8 MPH 72.79
    1000 ft 12.902
    1/4 ET 15.459
    1/4 MPH 87.60
    0-60 MPH 7.043
    VN executive 1310kg+75kg driver
    Optimal Spark 98 octane
    :thumbsup:
  2. kwik6
    kwik6 stroke it baby
    rowville, melbourne
    vz ss cobalt blue/ hk prem chev
    where did u do that?
  3. Full Spectrum
    Full Spectrum Bro it's a VW your Audi!
    Berlina V6
    What type of info would you need to do my VP, It's got some extra mods now does that matter? Very good grip with i only just found out the same tyres used on the VYII-VZ Calais:D. New tranny tailshaft etc. No memcal work runs on 91.
    I was trying to work out ruffly what power it has now?.
    And it was good to see the stock VP was the fastest:D
  4. greenfoam
    VP Executive R-spec
    Slickholden, I don't like to be the bringer of bad news but there's a very good chance your car would be no faster than stock (or even slower) once it has warmed up with the pod on it, just +15c worth of hot air could cost you 7nm of torque right through the rev range and that's most likely more than you gained back with the exhaust. Throw the pod to the tip :thumbsup: and get the coldest air into the thing you can and then go to repco or somewhere and get a cooler thermostat, around 175F or even a bit less than that AND make sure your throttle body does open 100% straight, those are things you can do that WILL make you car go faster and they are cheap.
    :driving:
    Worth a mention that all those calculated times are with a perfect air fuel ratio, something alot of stock VN's don't have anymore or never did have. That's why the perfect spark advance times aren't much different, because you gain most of your extra memcal power with the fuel ratio getting fixed, if that's allready ok you don't see much gain on the V6's (esp on the VN which is almost maxed out from the factory (but also most likely to have a crap air fuel ratio:)))
  5. Full Spectrum
    Berlina V6
    LOL after you said that about the pod i was sitting here thinking i think your right, When i had the air box on it seemed the same to me.
    I think my throttle body is up **** creek:D Not sure it opens 100% i believe it doesn't. I think it had a thermostat done before i bought it.
    All them cheap upgrades sound good to me as i really wouldn't want to go and do anything on the ECU at this time.
  6. FadeToBlack
    FadeToBlack Member
    VX II Calais L67
    And again how are these simulations done?
  7. greenfoam
    VP Executive R-spec
    I'll add a VT/X, makes quite a bit more power in the engine sim (I only have head specs, no cam yet so it might not be perfect) but the weight kills it
    Thu Jul 20 06 4:26 pm
    Time Slip For:
    VX/VT Executive sedan
    V6, stock tune
    RT .500
    60 ft 2.620
    330 ft 6.842
    1/8 ET 10.380
    1/8 MPH 71.12
    1000 ft 13.410
    1/4 ET 16.007
    1/4 MPH 86.20
    1560kgs+75kg driver
    The VY might be a little faster, or whatever model it was that got the dual cat exhaust as standard
  8. greenfoam
    VP Executive R-spec
    engine/drag race analyzer
  9. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    Does the simulator tell you when you have gone tooo far and put a rod out the block? Stock VN 3.8 & V8 driver
  10. greenfoam
    VP Executive R-spec
    Kinda, it tells you when the piston speed is excessive for stock style pistons and can calculate valve float and all that kind of thing (I assume perfect brand new springs/everything for these times). It's only as accurate as the specs you enter in, but if you get those right, it's spot on
  11. 88GreenVN
    Surprise, Arizona
    Sounds like fun stuff to do. Good work.
  12. holden007
    holden007 VRII
    Subaru Liberty
    No these are good VR results, not the 9.3 secs claimed by wheels magazine.
  13. greenfoam
    VP Executive R-spec
    Ah yeah no chance a VR will do 9.3 to 100 I doubt even a V6 Calais would be that slow, but remember 60 mph takes about .3 less than to 100 km/h. In fact I've driven a VR V6 Calais with my foot on the floor and it was pretty quick !:)
    My VN Lexcen (50?kgs heavier than an executive) runs 7.15 0-60mph all day with the stock chip and a CAI on it and can just crack it for a 6 with more spark advance. Macks VN executive used to do 7.3 stock but it's in Queensland with not so favourable weather conditions like I have down here in the deep south so I'd be up a fair bit on power just because of location. But both those cars seem to be close to their best possible time. A VS executive should be _slightly_ faster than all of the above cars or at least equal to them
  14. holden007
    holden007 VRII
    Subaru Liberty
    greenfoam
    You did a good favour for VR owners, I dont care if we are the slowest or fastest, but 9.3 secs, just crap. Thanks:)
  15. Full Spectrum
    Berlina V6
    I stuck back the Air box today, Slower take off i can feel that:(, But mid range power is wheel spinning. But the best thing was it's been a touch ruffer with the pod and as soon as the old Air box went on the idle everything went better.
    I did a sneaky i added a tiny bit of hose where the gap is in the front of the Air Box to between the light and radiator to hopefully trap some colder air up it. I could feel the sucking at my hand very easy.
