Single Legger VR or VS to Tow a Boat?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by dream888, Feb 8, 2013.
  1. dream888
    dream888 New Member
    VR V8 BT1, BMW Convertible
    Hi Guys
    New here.. I've had a search around by can't find any info to my exact question.
    So.. here is my situation:
    I would like to buy a commodore to tow a 1 ton boat.
    I really don't want to get anything older than a VR - and I don't want to purchase a 4WD..
    On a decent boat ramp would I have issues with a single legger VR or VS? These cars seem very affordable and have good towing capabilities but i'm skeptical about the traction.
    I was thinking I might have problems on the boat ramp, so thought I would look for a V8 which all have LSD diffs (+ hey, a V8 is always fun). Would the LSD give me enough traction to get up the ramp on low tide? The ramp is fairly good quality.
    If anyone here has experience launching a similar size boat with their V6 single legger, or LSD/ V8 etc I'd appreciate any comments.
    Dave
  2. VS-S
    Hey man I have no experience what so ever, BUT I reckon the weight of the boat would be enough to keep the wheels from spinning.
  3. yoshi87
    yoshi87 New Member
    south australia
    vs commodore
    depends on how wet the ramp is u might get some spin but if ur smart about it u can get it off the ramp with hardly any issues but would recommend trying a slow start in first gear, i have used a vs, vp, vr to tow car trailers and have no trouble with them at a hill start
  4. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    hrm, find a car yard close by with 1 for sale, take it for a test drive, hook up the boat and see what happens :p
    i've had a tandem & vt sedan behind a single spinner vn v6 before and never had a traction issue (even managed to beat the other lane across intersections from a red light.... few different cars and won each time..... they obviously couldn't drive) the boat ramps that come to mind from experience are rough concrete with bigger rocks thrown in the mix, decent angle... usually designed to grip better than tar....
  5. workvs
    workvs New Member
    nsw
    vs ute / ve thunder
    Hey. I have never had a problem pulling mine out of the ramp. And it's heavier than that. Just don't mash the go peddle and you will be ok.
    Mine is a ute though with tools in the back.
  6. dream888
    dream888 New Member
    Hey guys.
    Thanks for the replies.
    Sounds like a single legger should be able to do the job, with some care.
    Obviously if i can find something with a LSD that would be nice, but we'll see how it goes.
  7. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    A V8 will not make it grip better, and don't count on a LSD to grip better as they wear out and are slipping after about 100,000km. Keep as much weight as possible in the boot to keep weight on the rear wheels, and always carry a tow rope!
  8. aj159
    aj159 New Member
    VS CALAIS
    My dad used to own a vs calais and towed his 2.5 ton boat... only problem he ever had was at boat ramps with sand... always bogged but that was a really heavy boat so he went 4X4 but for a one ton boat should be no worries... towed my jet ski to boat ramps and never got bogged once... alot lighter than one tonne though
  9. immortality
    Sth Auck, NZ
    Get an auto, manuals make it harder unless you know how to slip a clutch but expect it to wear out quicker. Unless the factory LSD is worn out it will be fine in a straight line. Cheap enough to get rebuilt anyway.
    The biggest issue is how the weight is distributed on the trailer and towbar. Generally boats tend to be ass heavy once on the trailer because any water (and other weight like a good load of fish) in the boat will be at the back tending to try and lift the rear of the car.
    Also, if you do get an auto, make sure you fit the biggest trans cooler you can fit and service the transmission regularly.
  10. BxTom
    BxTom New Member
    I have a 5.2 mtr fibreglass halfcabin with a mercury 60 hp on it which I would say is about 800 kg or more in weight. I have no trouble on ramps with it. Mine is a 1995 VS V6 auto sedan and, as others have said, the auto is a lot better at ramps. Beware that if you are towing a boat in a commodore, make sure you have an automatic Transmission cooler and an upgraded towbar. I Have the 1200KG (I think) which has the extra bracing in the boot.
    Cheers,
    Tom.
  11. spauldj308
    spauldj308 S Pack Man
    Hobart, TAS
    VR S sedan 5L, VSII ute
    I towed our boat in my VR when it still had the single pegger, only had a problem if there was algae on the ramp, but I was gentle on the throttle.
    Now tow it with my manual VS V6 ute, with LSD, never been an issue. Just be gentle with it.
  12. BlackVXGTS
    BlackVXGTS Well-Known Member
    Melbourne, SE
    Sorry to disappoint you Dave, but LSD diffs were optional on VS V8s (and I suspect on VRs as well).
  13. immortality
    Sth Auck, NZ
    LSD diffs were optional on fairly much all models.
  14. Sabbath'
    Sabbath' Redblock Jesus
    80 Series// MK5 GTi//
    At low tide,on a slippery/algae covered ramp you WILL struggle with a single pegger no question.
    Sent from here, so you can read it there. via iPhone.
  15. Cava454
    Cava454 Member
    Box
    VR SS, VZ SS
    I've towed our boat 2 tonne plus, with old mans turbo diesel Mondeo. You will be fine.
  16. dream888
    dream888 New Member
    Thanks again guys. Sounds like for this small boat should be fine on single legger.
    Damn..
