plymouth_hemi_69
- May 1, 2009
- 564
- 1
- 0
- Location
- tearoha nz
- vs v6 turbo, vn v8 turbo
Hey i had a sc14 supercharger on my vs commie but have spoken to delcowizzard and he talked me into going turbo as the sc14 would run out of breath for what i wanted. Here is a list of what i needed and wanted to turbo it:
A t70 turbo $550
a intercooler 600x300x76mm $169
intercooler piping and joiners (2.5") spool quicker $199
transgo shift kit and corvette servo $350
2 hand gearbox with shift kit installed $850
a oil line kit $149
wastegate $160
bov 100
manuel boost controller $40
a reverse plenum $260 easyer to plumb piping to
6 x 36lb injectors $350 (s/c injectors)
turbo timer $300 has security lock feature
boost gauge $50
oil pressure gauge $50
head flange x 2 $89.10
t3 flange $46.60
buying the pipe 3mm thick steam pipe and cut $40
air intake manifold gasket set $65
hardened bolts and vacuum block $55
v clamp and wastegate flanges $50
k and n enclosed pod $350
extra silicon joiners and t clamp $90 reducers and alsorts
s/c v6 ecotec spark plugs $40
a very well tuned memical from delcowizzard ??
Also need the 3" exhaust made up and crossover pipe ??
Delco wizzard is been a big help with my project i couldnt of done it with out him and also iblown has given me alot of advice to thanks to you guys i have a near completed turbo car delcowizzard will be changing my vs ecu with a vr ecu so i can use a 2 bar map sensor and get rid of the maf (as you will see in my later pics theres not alot of room for my new pod filter) also will be doing a realtime tune to tune it perfectly getting a button put in the dash so i can push it and have instant higher boost (havent got to al this yet will let you guys have a look at progess before i go to far) my turbo will be running off all 6 banks and will have the crossover pipe at the back under my gearbox so unseen untill you get under there please enjoy my write up and any q's you might have i can try answer or try find out the answers cheers
A t70 turbo $550
a oil line kit $149
wastegate $160
bov 100
boost gauge $50
t3 flange $46.60
