Slight grabbing/bumpy feeling in front wheel
Lingdawg
Queensland
VY Storm
Hi guys
I have a vy ute and lately it has been like grabbing/grinding kinda feeling in my front passenger side wheel when I am going slow and braking at slow speed and also going around a corner with the pressure on that side, I can slightly hear it but can more feel it, a friend thinks my rotor might be warped but not quite sure?
When I jack the front end up and try to spin that wheel there is a point that it grabs a bit, but would this cause it to make a grindy bumpy feel?
IBLOWN
42
VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
Rotors have hot spots. Get them machined or replace them with a RDA/DBA units. Best to get the new units as the Holden ones will just burn up again.
Lingdawg
Queensland
VY Storm
Ok does what I explained sound like my rotor is warped or bad?
mpower
hot spots and pad material buildup =/= warped.
warping is a myth.
/awaits debate.
Mad84VK
VY S Ute
you can get cheap after market ones. just get new. and they sound warped. my rotors are warped pretty bad when i break heavy the steering wheel shudders. im new for new ones too.
Futech
Like a boss
Auckland, New Zealand
VY 5.7
Its called "runout" and there's nothing wrong with machining your existing rotors if they are not under minimum thickness.
