slow cranking speed when engine hot
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by justice4all3000, Sep 28, 2011.
  1. justice4all3000
    justice4all3000 Member
    VF Calais V
    I'm getting a very slow cranking speed while the engine is hot I have tried swapping the battery for a newer one and cleaning the battery terminals with no luck do I need a new starter motor? or have i missed something?
  2. strgas
    strgas GRA = REAL HP
    sounds like your starter motor is struggling when hot check your starter cable fit a heat shield common complaint when the starter motor is heat soaked , check your earth cable too clean and tight at the battery and the block
