Smaller belt
Hayden Beaver
Bungendore
2012 Ve series 2 holden commodore ute
Hey just a quick question. I have a 3.6L non supercharged V6 Ve commodore and the current belt on those cars is a Gates 6PK2555. I’m looking at dropping down to a 6PK2545 which is a 10mm / 1cm smaller belt. Does anyone know if that will increase or decrease power or affect the life span of the belt?
gossie
Gold Coast.
VE International 3.6L
Why change from what is correct?
Fu Manchu
WA.
The belt might wear faster?
No difference on power etc.
I’d be using the correct belt though.
On high revs, you might get some squealing.
losh1971
North Tas
VE Series I SS Ute
Not overly familiar with the Alloytec but if it has a belt tensioner like earlier models I would be sticking with stock length. Adding extra tension to the tensioner is a bad idea as it places additional pressure on the water pump bearing.
rtmpgt
33
Perth, WA
www.pgt.design
2010 VE1.5 SV6 Ute
If anything you're adding more wear to the belt, and you'd effectively reduce the power of the car due to the additional drag on the engine caused by the added tension.
The Alloytec has a belt tensioner, so there's no need to step down in belt size. Stick with the OEM size unless you're supercharged.
gossie
Gold Coast.
I notice good old Haydon never came back.
Obviously trying to be cheap and save 50c on an incorrect part eh Haydon?
