Fonzie
Just lost the game.
This could quite possibly be the dumbest question I've ever asked, and I'm missing something very obvious. You've been forewarned.
I recently got some 18"x8" rims for the VS so i can ditch the stockies. Got 16 wheel nuts and 4 lock nuts from repco. Problem occurs when i put the rim on the wheel studs. The wheel nuts fit in the holes, match the bevel, match the thread, and i can do them up hand tight. The X tool i have fits the hex size of the nut, but it doesn't fit on the wheel nut when it's in place. I used my expertise *cough* in paint to illustrate this (paint ftw.JPG). The green section illustrates the X tool.
I took some quick webcam quality pics of the wheel nuts... 01.jpg shows the end of the nut that faces the stud, 02.jpg shows the visible end when it's on the car.
Now.. the lock nuts i have (03.jpg) are like any other... When these are in place, i can put the key in and tighten them to where they need to be, because the key brings the hex head out past the rim face, and hence the X tool fits on it.
Question is, do i need to get wheel nuts that have a hex indent or something, and use some sort of allen key? Or can i get an X tool that has thinner 'sides' to fit between the nut and the rim? Or is this topic something i will have listed under greatest failures for the rest of my life because the solution is far too obvious?
