PaRaDoX
Because Racecouch...
- Apr 16, 2005
- 3,286
- 34
- 48
- Location
- Melbourne, Victoria
- none
hehe foam or it might be empty like yours
greenfoam said:Your catalytic converter is probably broken, 90%
HoZy said:Cat converter..... Whats a cat converter *shifty eyes*
MaT
vn6pwr said:Is that a good thing or a bad thing :whistling
PaRaDoX616 said:and some people wonder why we have a hole in the o-zone layer hehehe
bad thing, if the cat converter is clogged it would cause limited flow
HoZy said:After i get my p's , car gets back onto 95% Driving on gas....... So no cat converter doesnt matter.........
MaT
vn6pwr said:When do you turn 18 mate?
Ummmm i got it from united petrol station..... der a pretty gibby place sometimes.... 1 week there gas and petrol is ok and d next it makes ya car run like ****....PaRaDoX616 said:where are you getting your fuel from??? i wasnt aware of 94RON fuel, only 95RON which is the lead replacement and i run it all the time
yer ive dun dat and like no water goes on my hand... but wen i start it water dun come out of the exaust.... but not alot.. and it stopes after like 5 mins.... and it used 2 do dat ever since i got it... and as4 hed gasket or thermostat... my engine doesnt get hot really :S.... it jus stays like average heat and i let it idle 4 like half an hr to an hr... and i do that bout 3 times a week...ok, put your hand over the exhust, then smell it... is it water based????
if it is then it may be something like a blown headgasket, or even a thermostat thats jammed its self open/closes, which can cause the thermo fan not to come on and the coolant to cook but it shouldnt be comming out the exhust in that case
yer ill try that as soon as i can... cant really do it now coz its a lil wet outside.... typical melbourne weather haha.... and as soon as i get it registered im ganna put like 20-30 litre'z of high octane... and fill mah gas up...... and btw 98ron wont hurt mah engine will it?id reccomend running 1 tank of BP ultimate (98RON) through the car, and some injector cleaner couldnt hurt, and run a self diagnostic
for a self diagnostic you'll find under the glove box there is a connector, grab a paperclip, unfold it.. and use it to bridge the black/white wire on one end,
this will cause the engine light to flash when turned to 2nd ignition, the flashes represent a code which is a self diagnostic of errors, just a very basic one
it is comprised of 2 lots of flashes, ie 1 flash, pause, 3 flashes = code 13, 2 flashes pause, 4 flashes = code 24 here is a self diag list
fnx 4 the reply...VP_Luke said:how long has it been since you done your plugs and leads?
does the car drive fine? or does it stutter it's way around?
what's the idle like? is it an irregular erratic idle? or smooth? or is it a regular
