smidey
- Jun 18, 2012
- 222
- 2
- 18
- Location
- Northland, New Zealand
- VN SS WM 6L
I have owned this SS for around twelve years. It was heavily modified when i bought it and in the time i have owned it i have almost replaced all of the mechanical parts. When i bought it it had a fibreglass VR/VS clubsport front bumper and rear wing and the rear guards were rounded and am starting to put the body back to standard. It's evolving more toward how i want it all the time and i have most of the parts to get the rear end back to factory.
Series 2 Phoenix Red VN SS Power Pack (Export Model)
Engine: (184rwkw/527nm) K&N filter onto 72mm throttle body, ported heads, Kelford type D cam, comp cam pushrods, yella terra roller rockers, aftermarket pistons, shot peened rods and upgraded bolts.
Driveline: SV5000 Shift kitted trans with corvette servo with front mount trans cooler, custom two piece drive shaft onto 3.45 ratio LSD.
Suspension: Monroe GT Gas/GT Sport shocks with Cobra Superlow springs. Nolathane bushes all round. HSV swaybars and adjustable panhard rod. Kmac adjustable camber castor strut tops. Nolathane Upper Rear trailing arms.
Brakes: Wilwood 4 pot callipers with wilwood 13” GT directional vane rotors front, standard rears.
Exhaust: Pacemaker headers with twin 2.5” pipes all the way through to the exhaust tips. It has resonators toward the rear and a custom made stainless steel muffler. The system also has removable caps just behind the extractors for drag racing and removable caps just forward of the diff for track racing.
Interior: Calais leather seats with door trims re-trimmed in leather to match. Level 3 cluster and switch blocks, VN GrpA wheel, Pioneer mechless head unit with pioneer speakers front & rear. Electrical oil pressure gauge on dash.
Other mods: Cruise Control added. Electric radiator fan controlled with a thermo switch inserted into the thermostat housing.
Wheels: VZ R8 19s with 235/35 Potenza Front, 245/35 GT Radials rear
Calais seats with retrimmed door cards
Capped drag pipes just behind the pacemakers
Removable caps at the diff
Fan and front mount trans cooler. Fan controlled by thermo switch in thermostat housing
Thermo switch in thermostat housing
[img http://i56.photobucket.com/albums/g183/Smidey/Holden/P1040920_zpsaf18ba44.jpg[/img]
