smokey vs
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by josh_lock, Jan 9, 2013.
  1. josh_lock
    josh_lock New Member
    guildford
    VS 3.8 s2
    hey guys im in need for some help i got a vs commodore v6 i changed the moter i put a vt moter in it but ive got a problem somtimes ( 95% ) of the time when i start it up i blow alot of white kinda black smoke the it clears up in like 5 seconds or longer then dosent come back till i start it again and im lowy loosing power im puzzled and wanted to know if anyone can help me
  2. K-BAGZ
    K-BAGZ De Plane! De Plane!
    Far North QLD
    VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
    Looks like a blown head gasket, the white smoke being steam.
    Have you got a compression tester? If not, buy one or borrow one. Minimum compression of an Ecotec V6 is 100psi.
    Compression Test Procedure.
    1. Make sure you have a fully charged battery.
    2. Run the engine until operating temperature is reached.
    3. Turn the engine off and disconnect the spark plugs leads for the coil packs and spark plugs.
    4. Remove the engine and fuel pump fuses.
    5. Remove a spark plug and install the compression tester into whichever cylinder you want to start in. 1-6, 6-1, 1-3-5, 2-4-6. Whatever way you want.
    6. You need another person to fully depress the throttle pedal and crank the engine over. Only crank the engine a maximum of four compression strokes (thumps) at a time, while observing the compression tester gauge and note down the highest reading.
    7. Test the following other cylinders and compare all the readings at the end. The lowest reading on any given cylinder shouldn't be lower than 70% of the highest reading cylinder.
    If a low compression reading is noted on one or more cylinders, you can 'wet test' the engine to isolate the issue even further. Add a small amount of engine oil in the combustion chamber of each cylinder and repeat the compression test again.
    An large increase reading of compression pressure indicates that the piston rings, piston and/or cylinder bore are worn. A low increase reading of compression pressure can indicate burnt, obstructed or sticking valves or a leaking cylinder head gasket.
  3. josh_lock
    guildford
    VS 3.8 s2
    thanks buddy i will try that and see how i go
  4. Jonah 101
    Jonah 101 Undefined
    Rotorua
    R32 Skyline
    Check you fuel regulator too, sometimes the diaphragm splits and fuel enters the plenum via the vac hose. ( rich mixture black smoke )
  5. K-BAGZ
    Far North QLD
    As Jonah said - Check you fuel regulator too, sometimes the diaphragm splits and fuel enters the plenum via the vac hose. ( rich mixture black smoke )
    With the engine running, remove the vacuum hose from the fuel regulator. If fuel spurts out, the regulator diaphragm is fingered.
  6. josh_lock
    guildford
    VS 3.8 s2
    thanks guys could be why im useing so much fuel :)
  7. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    valve sleam seals, inlet manifold gasket....i wouldn't be suggesting head gasket yet, plenty of other cheaper things that can cause this lol
  8. josh_lock
    guildford
    VS 3.8 s2
    inlet manifold as in where the silver rectangle or as in the part to the head ?
  9. K-BAGZ
    Far North QLD
    Inlet manifold, which is located under the plenum.
    Pressure test the cooling system too, that'll isolate if there is an internal coolant leak. Eg cracked inlet manifold gasket, cracked cylinder head, cracked cylinder block, cracked cylinder bore.
    A perished valve stem seal will also produce white smoke out the exhaust as the oil is being burnt in the combustion chamber. It can be picked up by a dropping oil level measured on the dipstick. It would mostly produce a continuous small white smoke puff at idle though.
  10. josh_lock
    guildford
    VS 3.8 s2
    thanks guys it was the inlet manifold some how (id say the wreckers) the pcv value was in one of the in take ports havnt been smokey since i changed it :)
