smoking commodore
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by greenvs, Apr 3, 2007.
  1. greenvs
    greenvs New Member
    Northern Suburbs
    VS Caprice SII
    i have a mate with a 97 VS commodore with 245,000 kms which is producing white smoke out the exhaust when accelerating. What could this be?
  2. Spaced
    Spaced New Member
    1997 VS Commodore Exec
    posilby head gastket? Does he have oil in his coolant, does his coolant or oil look milky?
  3. greenvs
    greenvs New Member
    Northern Suburbs
    VS Caprice SII
    head gaskets been replaced but coolant has brown sludge resting on top. Any other suggestions
  4. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    Brown sludge..... well it COULD still be a head issue, if the head was warped slightly when the new gasket went in.
    If it is the head that is causing this white "Smoke" it would actually be steam :p
    Put your hand over the fumes and look at your hand, is there condensation ?
    otherwise could be burning some oil? but thats open for debate as when your accelerating id expect more blue smoke.
    Just a word of advise, I recomend NOT using chemi weld.
  5. HDT_aero
    HDT_aero Banned
    SA
    manual VN aero
    Smoke colour chart
    white = moisture
    blue = oil
    black = rich mixture
    most probably just condensation if it is just on initial startup
    if its all the time then its probably a cracked or warped head (presuming the gaskets are good as you suggest)
  6. ephect
    ephect Donating Member
    VS Acclaim V6
    desiel will give u white smoke also..
  7. Spaced
    Spaced New Member
    lol but I haven't seen any disesel commodores...........yet
  8. Bilbs
    Bilbs Member
    Morwell
    2016 VFII SSV Sportwagon
    Well, oil does burn blue smoke, but looks hella white unless youre looking at it in the right light, is it worse when you let it idle for a while, the accelerate, or is it just all the time, at 240,000 it MAY be th rings, if it is worse after idling for like 5 mins, then valve stem seals.
  9. The Darkness
    The Darkness Junk Yard Dog
    Ipswich
    Charged VT V6 A4
    **** i got white smoke on start up and idleing.....damn
  10. ephect
    VS Acclaim V6
    yea no desiel commys yet, but drop some desiel in the tank n watch the white smoke poor out! :)
    are we talking about 'white smoke' like on a cold morning and u exhale n everyone pretends to smoke a ciggy? that type of white smoke? but from ur exhuast? if so, totally normal..
    maybe you can give us a lil info, if it were rings, u'd be puffin out blue smoke on acceleration..
    does it blow white smoke on hot days when ithe engine is warm?
  11. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    I bet something is getting in the combustion chamber.
  12. sircruisealotVS
    sircruisealotVS Well-Known Member
    South Brisbane
    VZ LS1 Calais
    best and easiest way to work out what the hell the smoke has in it is to get a very clean white rag, place it over the end of the exhaust and hold it there while you start the car. let it idle for a while and then give it a few light revs, then turn it off and have a look at the rag.
    if it has lots of black specs all over it - you've got oil. if it is clean but has become damp - then you've got water.
    once you've actually worked out what is burning off in the exhaust to make the smoke then you can go about fixing it....your just guessing otherwise.
  13. The Darkness
    Ipswich
    Charged VT V6 A4
    i know there is moisture in mine with white smoke on normal day. not cold. does that mean head gasket?
  14. DannyboyDS
    VS Berlina
    Great Post SirCruiseAllot.
    Infact Excellent post.
  15. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    Also make sure that there is no water in the exhaust system!!! My dad washed his car last with a high pressure hose and without realizing it that he was getting water into the exhaust pipe, but it would take a while for it to get hot down that end and blow smoke so that would be very unlikely in your situation.
  16. shumway
    shumway Son of satan
    some where between heaven and hell
    VS 6/71 blown and injected 355 V6
    I havent seen to many diesels blowing white smoke,usually black smoke and thats due to dirty injectors anyway.It would have to be pretty flogged to blow white smoke
  17. ephect
    VS Acclaim V6
    yes thats coz diesel engines dont have spark plugs, the deisel isnt ignited, its compressed.. but drop it in a ignition engine, n she'll bellow white smoke :)
  18. evil_monkey
    evil_monkey New Member
    Australia
    Holden
    your car has a drug problem, perhaps an intervention ?
  19. The Darkness
    Ipswich
    Charged VT V6 A4
    lmao. thats classic
  20. DannyboyDS
    VS Berlina
    so 100ml of diesel in my worst enemy's fuel tank?
