Snapped a bolt when putting water pump in
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by havavb, Oct 5, 2011.
  1. havavb
    havavb New Member
    VY S Ute
    I changed my water pump to a second hand one for now, when I put it in I snapped one of the bolts, how do I get the snapped bit out? Just want to know for when I buy a brand new water pump and put it in
  2. Wombles
    Wombles Cars cost too much.
    Does it leak?
    is there a stud sticking out?
    If not you may have to drill and use an easy out.
  3. Reaper
    If it is going into cast iron then you have a good chance that the broken off bit will just wind out with a screw driver or even finger tight. If it's into aluminium then try vice grips or whatever you can get onto it. Maybe consider a new timing case - if it's a V8 they are not expensive.
    Reaper
  4. bogan_vk
    bogan_vk New Member
    australia
    commodore
    if is flush with the waterpump just use locking multi grips when you change the pump it will come out easy , but if its snapped flush with the block then its a drill and an easy out either way it will come out ive snapped a few in my time and never failed to remove one using these methods.
  5. mr calais 5.0
    mr calais 5.0 New Member
    victoria
    vy s 2003
    A easy out will do it.. Just take your time or if it's gone bad you could drill it and cut a new thread.. V8 or v6?
  6. shane_3800
    shane_3800 Active Member
    places
    vr commo
    if none of the above work it is time for a helicoil
  7. ryan21
    ryan21 New Member
    89 vn calais v6
    i had to do that, god damn that was not fun especially when i tried to tap it out before hand, looked all good put put it all back together and the bolt just chewed the thread out. but the heli coil worked really well
  8. havavb
    havavb New Member
    VY S Ute
    Might just use the drill, no chance of multigrips getting this one off lol
