snapped bolt on water pump
Discussion in 'VB - VK Holden Commodore (1978 - 1985)' started by Goon, Jul 27, 2012.
  1. Goon
    Goon Scientific Tuning
    BrisVegas. QLD
    VY CUSTOM.
    snapped the lower water pump bolt using to much force after using the incorrect bolt, i got to keen.
    tried centre puncher , drill , easy out , multi-grips and chisel .. all failed any other ideas??
  2. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Well sound like the bolted is stuffed. Keep drilling
  3. m1lky
    m1lky New Member
    Auckland
    VY SS
    Screw remover? Or weld a nut to it and unbolt
  4. vkberlina
    vkberlina VK Madman
    NSW Central Coast
    warm the block and bolt (NOT HOT) try some freezer spray on the bolt to try and crack the rust etc, do it a few times then weld a nut onto it and undo
    scott
  5. Goon
    BrisVegas. QLD
    VY CUSTOM.
    thanks guys, ill try welding a nut, was so keen to fire it up this weekend.. been working hard on this build.
