Snapped Strut Stud!!! HELP!!!
S2_VR_
Northern Rivers, NSW.
03' M6 VY SS ute
hi guy's i overtightened one and it snapped, is 5 tight ones ok???
or should i replace it before i drive again??????
thanks guys
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
Uh if it was me, Id be replacing it before I drove anywhere.
Also replacing all of them, and torqueing them correctly.
S2_VR_
03' M6 VY SS ute
i did a google and found that guys with subaru's have done it and driven on 2 b4, has anyone had this happen too them?....
Deathproof
WH Stato
Just knock the old one out of the strut in the car with a hammer and pin punch,tap one carefully out of your spare bearing top and fit it in from underneath...if you cant get at it to tap it in from underneath,CAREFULLY pull it through with the nut and some washers...
Sounds hard.is pretty easy and quick...
Id drive on it if I needed,but get it fixed ASAP
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
My personal opinion is that I wouldn't worry about it. 5 out of 6 is pretty good plus they really only locate the strut and stop it pulling out. The next model (VS) only used 3 studs of similar dimensions so the VR was over- engineered.
Glue the broken stud over where it broke so it looks OK (I didn't say that)
The only way to replace the stud is a new strut and all the hassles involved.
S2_VR_
03' M6 VY SS ute
ok those two post's contradicte eachother.......??...so can i do this or do i need a whole new strut??
S2_VR_
03' M6 VY SS ute
they are pedders lowered strut's and i cant fork out another 150 for another strut.....can the bearing plate be changed???
Deathproof
WH Stato
So youre talking about the bolts that hold that plate to the strut tower right?? (The ones that secure that strut brace)They have NOTHING to do with the actual strut itself...as it pushes through that plate and the round washer and a nut secures it...
Apologies about the pic,I stole it from another thread on here...
