acarmody
Donati..Whoa Green
- Apr 29, 2007
- 5,920
- 56
- 48
- Location
- Brisbane
- VX Berlina
I got a bit bored so I Tried to design a sub box for you. Keep in mind I'm not an expert by any means.
Using 3/4" MDF. With dimensions from specs I posted. Nothing in this diagram is to scale, all hand drawn in Paint, bloody text writing wasn't working for me so writing is dodgy. I worked with sides being 16.5" x 13.5", top/bottom being 16.5" x 16.5", and front/back being 16.5" x 12" obviously front being 1.5" shorter for port. Port runs top to bottom and does a 90 degree bend at the back. Start with bottom lying on bench, stand sides on either side so that sides are on bench (not sitting on bottom), nail/screw/glue together, then do same for top. Front and back go into the gap. I only did that way so that the front and back can be heavily screwed together from all sides.
Sorry about small picture.
EDIT: Actually on second thought, assemble all pieces except the top, then assemble the port walls in the box , THEN add the top. How could I forget the port walls, tired I guess.
